Contact storage draining my battery
(Topic created on: 11-02-2024 04:20 PM)
shakiromer
In battery usage section there is one app called 'contact storage ' is draining my battery. And i cant see this app anywhere else in my phone. Please help someone to find out the issue
10 Comments
ojwh
Hello. Sorry to hear this. Do you have a screenshot of the Battery activity or Battery tracker, showing that contact storage is draining your battery? Or any screenshot that indicates this?
shakiromer
Yes, sure
shakiromer
Check this1730620456146_1730620456138_0.jpg1730620472694.jpg1730620472710.jpg1730620472730.jpg
Samsung_specialist
We sincerely apologize for the inconvenience you're experiencing. To help resolve this issue, please follow these steps:
Go to Settings > Apps > Show system apps.
Search for Contacts Storage.
Tap Force Stop, then select Clear Data.
If the issue persists after trying the steps above, we recommend submitting an error report for further assistance. Here's how:
Launch the Samsung Members app.
Tap on Support, then scroll down and select Send Feedback.
Tap the pen icon, and select Error Reports.
shakiromer
Still having the same issue
Jaffarjas
Beginner Level 4
Yes
shakiromer
The app is eating my battery drastically
R4tn1k
I have same problem
shakiromer
Thank you so much
