Battery Draining Issue - Samsung Galaxy S24 Ultra
(Topic created on: 09-11-2024 10:58 AM)
Kev96
Fix contact storage draining battery 🔋
Nothing will work. I have tried everything .
Follow these steps below. If it works, just coke below because it worked for me.
1. If your contacts are on the phone or Google contacts, move them directly to your samsung account preferred or phone storage.
2. Clear your cache.
3. Disable all Google contacts sync if you have multiple Gmail account disable contact sync on all accounts.
4. Then please restart your phone.
Note: All Google contacts sync should be disabled if any.
Then, charge it to 90 % and check if it worked for you.
It will work for sure if you follow these steps. After so many attempts, I found it, and I fixed it. ✌️
3 Comments
ZK0007
Storage is draining the battery?
If so, Are you using dual messenger (Whatsapp or any other)?
Otherwise, go to settings/apps and search for Google play services. Scroll down to App details in store and tap. If there are any updates available, update and restart the phone.
Kev96
I'm using dual whatsapp , but it was not the issue. The issue was in contact only. Contacts was drawing battery. Now, after moving contacts from Google to Samsung, no issue.
With the new update my battery timing has increased
