Charger Problems
(Topic created on: 05-12-2024 01:33 PM)
spookyEnigma
Last night I was charging my phone, suddenly it stopped charging. I thought there was some issue with my phone, but when I charged my phone using my fathers charger it was working fine.
I then looked at my charger, there was a slight burnt smell, but my charging cable was damaged. There was a bluish fluid inside the cable port.
To crosscheck, i used another type C cable with my charger and tried charging my phone, the brick was fine.
I understood the problem is with my cable, but I am not sure if my charger brick is alright as it has a slight burnt smell coming out.
I purchased the brick, back in 2021.
Please let me know, what to do. Should I go for a new brick? Or continue using my old one, with a new charging cable?
Bluish Fluid in my Cable
3 Comments
Aculite_29
If it charges with another type C cable, then your brick is fine.
Just grab a new cable.
Pawar07
Purchase new USB cable .
Port is water 💧 or liquid damaged
cs_member10
Dear Samsung Member,
As per your query, we would request you kindly visit the service center and inspect your device charger with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
