10-11-2025 10:37 PM (Last edited 10-11-2025 10:38 PM ) in
Galaxy S- Mark as New
10-11-2025 10:47 PM (Last edited 10-11-2025 10:51 PM ) in
10-12-2025 10:30 AM in
Galaxy SDear Samsung Member,
Kindly check the power socket functionality with a different device or try to charge the device in a different power socket.
1. Check connectivity: Please check whether the charger cable and adapter are fixed well. Remove the charging cable and reconnect with the mobile phone properly.
2. Check charger functionality: If different devices charge with the same charger. It seems your charger is functioning, before getting into the mobile-related troubleshooting, I would like to know whether you are using a Samsung-approved charger.
Note: We recommend our customers use only Samsung-approved chargers, as 3rd party chargers with different output ratings may cause errors in the device.
If the device charges with a different charger: It seems there is an issue with your charger, kindly check the physical condition of your charger for any damage.
3. Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
4. You can reset your device by following the steps.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
10-12-2025 10:56 AM in
