Charging problem till 20% in S24 Ultra
(Topic created on: 07-19-2025 12:18 PM)
HemuGS
 suppose if i start to charge at 5% the charging will stop and start automatically for every one percent till it charge to 20%((if it jumps from 5 to 6% the charge will stop and agian turn on for every percent till becomes20%)) , after 20% it will become normal but below 20% it is keep on turning off and turning on automatically, can anyone help with this issue, even though my charger and charging port is good no fluctuation of power in my home, can anyone help what this issue im facing
4 Comments
SevenWaves
Hi..
Try going to the settings and select battery & device care..
There, go to battery options..
There try enabling the "Protect the battery" option.
Then restart the phone, connect the charger and check.
Also try disabling the fast charging mode in the battery settings & try out the result.
goodthings
Please reset all settings in general management settings also flight ✈️ mode on n off one time also optimize your's device in device in device care too also clear catche of all apps manually also update your's all apps also charge your's device in cool atmosphere then try to it's again. If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
i_ashu
Same thing happening with me
