Camera settings || Aperture & Shutter speed
(Topic created on: 04-04-2021 11:56 AM)
Atishay29
Hi members,
Using S21 ultra and all I wish to know is do I get an option of setting Aperture and shutter speed I mean in pro mode one is visible and i believe setting the shutter speed automatically sets the aperture.
Please correct me if wrong
I wish to select shutter speed and aperture manually
13 Comments
Not applicable
Shutter speed doesn't change aperture
Atishay29
Then how to set that? Please advise from the above options in the screenshot. These are the only available options appearing
Not applicable
You cannot set aperture in S21 Ultra
Atishay29
Okay thanks
Not applicable
Welcome 😊
If helpful accept as solution by clicking on 3 dots of my comment
vishal261214
S21ultra main lens aperture is f1.8 only not change like s9 and s10 sereis f1.5 to f2.4
Atishay29
Thank you
Anikroyale
S21 Ultra does not have dual aperture, so you cannot change it. And shutter speed does not change aperture.
Atishay29
Thanks got it. Simple means I cannot change the aperture
