03-29-2019 10:21 AM (Last edited 09-25-2019 06:58 PM ) in
Galaxy SThe Galaxy S10 range has a whole host of cameras; so what better way to make the most out of them than Pro Mode in the Samsung Camera App.
Pro Mode Manual Adjustments
Pro Mode is available when shooting through the rear cameras. Select Pro Mode from the options at the bottom of the Samsung Camera app to make manual adjustments to the following:
- ISO: Set the ISO between 50 and 800
- Aperture & Shutter Speed: Select between the f/1.5 and f/2.4 cameras and adjust the shutter speed between 1/2400th and 10 seconds
- Standard: Adjust colour temperature, Tint, Contrast, Saturation, Highlight and Shadows individually
- Manual Focus: Tap the Auto Icon to switch to manual and use the slider to adjust the focus
- White Balance: Tap the Auto Icon to switch to manual, and use the slider to adjust the WB
- Exposure: Push or pull the exposure -2 to +2 stops
Pro Mode Settings
Tap the Settings cogwheel in the Camera app to turn on Grid Lines (3X3 and Square) or Save Options; shoot and save both a JPEG and RAW copy of your photo. You can also select to save images in HEIF (High Efficiency Image File) to save some space with this advanced compression format.
The Problem
The only problems is the no use of telephoto lens and ultra wide lens as you can't use it without the stock camera app also no raw photos from the mentioned lenses . No telephoto lens use in Filmic Pro (but iphone can use )nor in any other app and no raw images from front camera and other camera modules.
Some times i want to take those untouched selfies so that i can edit them as i want. Whats the problem samsung?
03-29-2019 12:07 PM in
Galaxy S- Mark as New
03-31-2019 03:57 PM in
Galaxy Sthanks for the info
04-02-2019 04:29 PM in
Galaxy Shappy to help
04-22-2020 03:47 PM in
