Battery related issue
(Topic created on: 08-02-2025 11:12 PM)
SwarnaliS
Today my galaxy s25 charging slowly and it drained battery too fast. Like 72% to 17% in 30 mins. Any solution regarding this... Please help. I bought this mobile last month.
6 Comments
SuMiT12301
I'm sorry but practically this should not be occurring. Please check whether your model is brand new or not because many duplicate and refurbished models are available in the market.
Match the IMEI code in the device with the one in the box. If both does not match, then be assured that you've been robbed. It's a very expensive device.
virk111
It can happen sometimes.Refill it again and see how it goes off
akash00_0
Jao lekr service centre
goodthings
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
● We always recommend to use genuine Samsung charger for charging your device.
● Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged, then kindly visit your nearest service center to get it replaced.
● Kindly check the charger functionality with a different device or try to charge the same device with a different charger.
● Check charging: If rating is 15W or above: Kindly try to charge the device in a non-inverter socket.
● If you using normal socket: As a safety measure Fast charging may not support, while you are using the device hence, request you to keep the device idle and check the charging performance.
Note: Kindly open Device care from settings > tap on Battery > tap on More battery settings > Fast charging > Turn on.
● Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
● Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
● Kindly check if ''Multiple applications'' are running in the background of the device. When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them.
● Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
● For battery drain Kindly Follow the below steps:
● Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
● Perform Battery Optimization: Go to Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage, and Memory.
● Turn off Wi-Fi, GPS, Bluetooth etc. when not in use.
● Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
● Reduce the display brightness level or set the device to auto-brightness mode.
● Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
● Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
● Close background running apps.
● Turn off auto sync of e-mails, app data etc.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
