S24 Ultra battery backup issue
(Topic created on: 08-02-2025 10:47 PM)
bryanS24ultra
Battery backup is being too poor after updating to u.i 7.0.
Why this is happening with me ????
2 Comments
BiRdMaN
Send an error report along with log files to customer support through this members app, and Samsung will add/fix it in the next update. To do that, follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, I'd appreciate it if you could ACCEPT it as a SOLUTION. Thank you 😊
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
