Battery percentage drop
(Topic created on: 07-06-2024 08:37 PM)
Vicky12341
Hello everyone any one facing battery percentage drop after 10% reached in S23 base model? Within 2 minutes it's goes down 10%-0%???
6 Comments
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
john163
mohit121
Its same for s22 ultra bro
Sameer
Watch this video specifically created to enhance battery life of Samsung phone.
Its all about the settings which you need to customise to improvise the battery life.
https://youtu.be/DXM7pdW5a-w?si=j5f25QhyUP0FqQ2Y
Wait for over a weeks post the making these changes in the video ...for the phone to study the usage patterns and enhance battery life ..
Many more exclusive videos coming up with lot of tips, tricks, automations, customisations only meant for Samsung phones.
Do Subscribe to this video and click the Bell 🔔 for all exclusive videos on Samsung smart phones.
cs_member10
Dear Samsung Member,
We want to inform you about the Samsung Members app (Battery Status (Battery life + Battery Capacity).
You can check the "Battery Status (Battery life + Battery Capacity)" test using the Samsung Members app.
Battery life depends on how the battery is used. Note that different devices have different battery life. The expected battery life for your model can be found in the manual.
We would like to inform you about the standard charging procedure (charge in one go instead of charging many times as it affects the life span of the battery and battery performance).
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory.
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level.
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps.
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
vinayshah
From 15% onwards, battery drain will be super fast so that users don't use the phone in low battery situations. It's basically 5-10 minutes of battery only. According to the article I read on the internet, it is to protect battery life. Though I didn't understand the logic but I accepted the fact.
