Question for S23 users about idle battery drop
(Topic created on: 05-21-2025 12:48 PM)
Istayhere
earlier s23 in Idle mode for example at night the battery percentage used to drop significantly less than what it's right now. After one ui 7 at night in idle mode battery is dropping more than 5/6 percent!! One ui 7 is still problematic
4 Comments
SatsangiDevan
Disgusting samsung service
BiRdMaN
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
Istayhere
The thing is, it has been 23 days since it was last updated(Oneui 7)
It doesn't need more than 4 5 days to re optimised
Royal_RJ
True one
