Battery issue after security updates
(Topic created on: 08-03-2024 03:21 PM)
فــيصل
After the last security update in July, the battery started draining strangely even without using the phone, but this will not laugh at us as we realize that it is a deliberate move in order to consider
buying a newer phone.
Did you encounter this problem?
4 Comments
samsungNerd
Which phone are you using ? And check in settingd>device care>battery which app is causing to drain battery in background you can restrict that app to run in background
فــيصل
I did it, S23 ULTRA
s7777
I have the same problem as you and the same type of phone too. I don't use the phone when charging.
Samsung_specialist
To address the battery drain concern, we recommend performing additional troubleshooting steps to identify the root cause of the issue. These steps may include:
1. Update Software: Ensure that your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
   - Step 1: Go to Settings > Software update.
   - Step 2: Tap on Download and install.
   - Step 3: Follow the on-screen instructions.
2. Setup Phase: Your new phone’s battery may initially drain faster as you set up applications and features. This is part of the setup phase, and background operations are optimized during this time. Allow a few days for all background operations and syncing to complete.
3. 5G Service Impact: While connected to a 5G network, your phone may consume more battery than usual due to the high-speed processing of large-capacity data. Consider optimizing overall usage and adjusting background usage limits.
4. Optimization Steps:
   - Open Settings > Battery and device care > Optimize now.
   - Adjust Background usage limits: Settings > Battery and device care > Battery > Background usage limits.
5.  Use adaptive battery: Settings > Battery and device care > More battery settings > Adaptive battery.
If you have attempted these steps without success, we kindly request you to visit the nearest service center for a physical inspection of your device. You can locate your nearest service center using the following link: https://www.samsung.com/ae/support/service-center/
