Resolved! Solved
Battery draining rapidly
(Topic created on: 06-25-2024 07:35 PM)
atulx07
I purchased Galaxy S23 on 20 June 2024. And the  battery is draining Rapidly. it  dropped  five percent in  fifteen to twenty minutes. Is it normal?
goodthings
Your's device is very new so please give it's some time. After some time and after some updates all is well. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
8 Comments
MR_PRIME
Depends on usages pattern.
atulx07
How much SOT should I get on normal usage?
MR_PRIME
5 to 6hr on 100% charge
atulx07
As of now I'm getting 4 to 5 hours while keeping mobile data or wifi turned on throughout the day.
Watch this video specifically created to enhance battery life of Samsung phones ...
https://youtu.be/DXM7pdW5a-w?si=4ViI0DhjN4qmVjWG
Wait for 2 or 3 weeks post the making these changes in the video ...for the phone to study the usage patterns and enhance battery life ..
Do Subscribe to this video and click the Bell 🔔 for all exclusive videos
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps in the link below.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
