S24+ battery issue
(Topic created on: 03-25-2025 05:42 PM)
xinxin
I just bought s24+ from flipkart for 57k.
The battery is having issues.
Its draining rapidly, I'm getting battery 3 to 4 hours screen time on wifi,dim screen, hd+ resolution, normal refresh rate, lite processing profile, disabled background and put every app to deep sleep except WhatsApp.
They said it's high density battery. This is not a flagship battery, its very poor performing.
Its discharging at 1 percent per minute of usage.
6 Comments
xinxin
Is there a fix to this. I want this device or the battery to be replaced immediately. This is BS!!! The free replacement period is over. What should I do?
Soul_Catcher
I also purchased this phone with 66k and even after 6 months it has same battery drain issue. The battery can't be replaced.
goodthings
Your's device is new so please give it's some time. After some time and after some updates all is well. So please don't bothered about this issue now. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
xinxin
Nothing improved with the steps. Battery is rapidly decreasing with very less usage. Its almost a month now.
