Heating and Battery Drain issue after January 2025 update.
(Topic created on: 01-22-2025 01:03 PM)
archit53
Recently updated my Galaxy S23 for the latest security update. Noticed that it started to get heat up and battery gets drained rapidly after normal usage.
Please fix this issue for Galaxy S23.
9 Comments
Royal_RJ
I am also facing the same, but others were not getting these issues.
archit53
Will have to monitor device for 2 - 3 days. Let's see if the condition remains the same.
I'll post the update
goodthings
Vishk92
i do not see any option as error report in my members app
goodthings
Please go to main page of Samsung Members App, click on support, click feedback, click error report then follow instructions on screen. Log files automatically send by system immediately after send error report. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device battery drain issue:
▶ Galaxy device heating issue:
1. Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Uninstall the unnecessary apps.
3. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
4. Avoid usage of mobile phone when charging.
5. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
6. Reset the device:IMPORTANT:
• For this:
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
archit53
After 24hr of observation, seems like issue with heating and battery draining has been resolved on my device.
Samsung_VkuAIb5
I am also facing the hitting rapid battery drain issue. Till update battery, phone was working fine but after update having hitting issue frequently and when phone got hit battery starts to drain fast. Camera quality also dettoriated. I don't why once some new series launched deliberately they try to dettoriate the existing flagship phones. If this continues definitely my next phone is not Samsung.
Hope the problem get resolved soon
