Heating and Battery darin issue in S23 ultra
(Topic created on: 03-25-2025 12:31 AM)
Saashy
I have Samsung s23 ultra. Which was giving very good performance and battery backup till December. But after the patch updates of January-February and March, heating issue and battery drain issue has increased in it. Earlier it has been seen that companies used to deliberately put such bugs in the software of their old devices to sell their new series. Now this time Samsung has done the same thing. Now Samsung also deliberately slows down its old devices by putting bugs. They have brought the problem of heating issue and battery drain in January-February March update. S23 Ultra s23 entire series used to give 5 to 6 hours screen on time normally. Now they are able to last only for 4:30 hours. Samsung should not do this with its customers. Samsung should not do low and cheap things by lowering the performance of their old devoces.Samsung has earned a lot of name and now it is doing such things which bring it to a low and low category. If Samsung has any humanity left in it, then they should fix it in the new update. They have deliberately put this heating issue and battery drain issue in people's devices through the update and now the customer cannot even downgrade it because they have written this in their January update itself. They should fix it and keep their humanity intact.
7 Comments
WelcomeBlack
Same with me, i jist bought the phone 6 months back
Karthikultra
Beginner Level 4
Yes same i am getting lot of battery drain
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
4. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
5. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
8. Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
AudioJack35
Yes new updates are cooking the device
You could ag Samsung official accounts on social media to raise awareness about the same
goodthings
goodthings
Your's most welcome to here.
drviper
It is mainly due to summer. Increased temperature.
