01-29-2025 06:59 PM in
Galaxy SSolved! Go to Solution.
01-29-2025 07:07 PM in
Galaxy S- Mark as New
01-29-2025 07:06 PM in
01-29-2025 07:12 PM in
01-29-2025 10:29 PM in
01-30-2025 09:33 AM in
Galaxy SDear Samsung member,
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
