Resolved! Solved
Battery drained
(Topic created on: Wednesday)
Ajaharuddin07
On my new s24 plus battery drained soo fast . I bought this device 7th june . I did everything but none of those worked .
2 Solutions
vivek006
It will optimise by end of this month don't worry.
Even I bought the same phone in may-2025 & by june it optimised & getting SOT around 6+hrs(No gaming) with 25 to 30% left by night.
vivek006
9 Comments
BiRdMaN
Send an error report along with log files to customer support through this members app and Samsung will fix it in the next update
If you find this helpful please Accept it as a Solution Thank 😊
Ajaharuddin07
How to report ?? And where i find log file ?? Plz tell me
BiRdMaN
On samsung members app find support at the bottom
Click and send an error report
Please Click on the 3 vertical dots and Accept as a Solution
vivek006
Ajaharuddin07
Any others problem do you have??
vivek006
Nope
goodthings
goodthings
Your's most welcome to here.
anshu776
I am facing same problem on my s24+. I bought this mobile on 6 may and i am getting only 3-4 hr screen on time with normal uses no gaming no video play only internet surfing, i have made every setting to save battery but no improvement ,,,,
