Battery Drain
(Topic created on: 05-24-2024 10:11 PM)
Mohammed_Sahadat
Hello Friends,
I'm having battery drain issue on my Samsung Galaxy S22 plus (Snapdragon version) after updated to One UI 6.1.
If anyone knows the solutions, please notify me.
Thanks.
Mohammed Sahadat
6 Comments
Same here bro, see the funny answer from, samsung without addressing about software issue.1716574536502.jpg
Thanks for sharing Samsung response on this issue.
It could be One UI 6.1 issue which hopefully they'll fix in next security update.
Anuraj111
Thanks bro
Pruone
You need a factory reset , after every major updates, so this will.clear all the old cache files which cause bugs....
Samsung_specialist
To address the battery concern, we recommend performing additional troubleshooting steps to identify the root cause of the issue. These steps may include:
1. Update Software: Ensure that your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
   - Step 1: Go to Settings > Software update.
   - Step 2: Tap on Download and install.
   - Step 3: Follow the on-screen instructions.
2. Setup Phase: Your new phone’s battery may initially drain faster as you set up applications and features. This is part of the setup phase, and background operations are optimized during this time. Allow a few days for all background operations and syncing to complete.
3. 5G Service Impact: While connected to a 5G network, your phone may consume more battery than usual due to the high-speed processing of large-capacity data. Consider optimizing overall usage and adjusting background usage limits.
4. Optimization Steps:
   - Open Settings > Battery and device care > Optimize now.
   - Adjust Background usage limits: Settings > Battery and device care > Battery > Background usage limits.
5.  Use adaptive battery: Settings > Battery and device care > More battery settings > Adaptive battery.
If you have attempted these steps without success, we kindly request you to visit the nearest service center for a physical inspection of your device. You can locate your nearest service center using the following link: (https://www.samsung.com/ae/support/service-center/)
@Samsung_specialist, Thanks for your update.
My problem was solved after May security update.
