Showing results forΒ
Search instead forΒ
Did you mean:Β
πŸ”‹ Battery Draining 😨
(Topic created on: a month ago)
IamAz
Has anyone faced battery draining issue after one ui 7.0 update in s24 ultra???!!!
C'mon, seriously??πŸ€·β€β™‚οΈ
19 Comments
Aamir_Butt
yes same issue with my S24 ultra as well
Expert007
Check in divice care - battery usage details..
IamAz
No changes
itsArshie
Beginner Level 3
Yes, battery draining fast
mohd93
Yes same issue I noticed after updating UI7 in my S24 Ultra
VikrantTambade
It is recommended to wipe your cache partition through recovery mode after every update. It will solve the problem.
VikrantTambade
@IamAz, actually, I am seeing your comment in notifications only and replying.
It won't wipe your storage.
If you don't know how to do it then you can watch YouTube tutorials.
IamAz
Thanks bro.. i actually did it with tutorial...
Let's see if this makes any change to battery life.
I'll update the result later.
VikrantTambade
Good πŸ‘
I mostly does this after every major and security patch updates.
