S23 battery draining issue
(Topic created on: 3 weeks ago)
sreehari1
Battery draining after update
5 Comments
Anuraj111
Hi bro I was facing the same issue till yesterday and also my phone is brand new ,but after resetting the phone, the battery drain is fixed .
MithinXavier
Me too have same issue. Need to do factory reset or only setting reset
Zammi
I'm hearing that June update is specifically addressing battery issues. Some people received the update this week are happy with the battery life. If all goes well, we will get the update next week.
Pruone
Do a factory reset after major update, it will solve majority of the issues
Samsung_specialist
To address the battery concern, we recommend performing additional troubleshooting steps to identify the root cause of the issue. These steps may include:
1. Update Software: Ensure that your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
   - Step 1: Go to Settings > Software update.
   - Step 2: Tap on Download and install.
   - Step 3: Follow the on-screen instructions.
2. Setup Phase: Your new phone’s battery may initially drain faster as you set up applications and features. This is part of the setup phase, and background operations are optimized during this time. Allow a few days for all background operations and syncing to complete.
3. 5G Service Impact: While connected to a 5G network, your phone may consume more battery than usual due to the high-speed processing of large-capacity data. Consider optimizing overall usage and adjusting background usage limits.
4. Optimization Steps:
   - Open Settings > Battery and device care > Optimize now.
   - Adjust Background usage limits: Settings > Battery and device care > Battery > Background usage limits.
5.  Use adaptive battery: Settings > Battery and device care > More battery settings > Adaptive battery.
If you have attempted these steps without success, we kindly request you to visit the nearest service center for a physical inspection of your device. You can locate your nearest service center using the following link: (https://www.samsung.com/ae/support/service-center/)
