Battery drain
(Topic created on: 4 weeks ago)
Ahamed7
Anybody facing battery drain issue after one ui 7 update for s24 ultra i need to charge atleast 2 to 3 time within 24 hrs.
9 Comments
Yes
Johnnabih
Beginner Level 3
Same problem
Anil_Sharma
Yes
Sidlol
yeah, drains too quick on z flip 5
saud971
Yes
VikrantTambade
It is advised to wipe your cache partition through recovery mode after every update. It solves the problem.
Tutorials are available on YouTube.
Sidlol
any links?
Samsung_specialist
We’re truly sorry to hear about the inconvenience you’re experiencing, try the below steps that may assist you.
1. Clear Cache: Go to Settings > Apps > One UI Home > Storage > Clear Cache.
2. Update Software: Ensure your device is running the latest software version by going to Settings > Software Update > Download and Install.
3. Disable Unnecessary Features: Check for any unused features or widgets that may be consuming battery.
4. Force reboots your device by pressing and holding the power and volume down buttons simultaneously for more than 7 seconds and your device will reboot.
