note 8 display problem
(Topic created on: 04-19-2020 10:35 PM)
no-name
Galaxy Note
Black Crush and Gradient Banding Issues
Is that any one facing the same ??
12 Comments
iamrohitkm
Galaxy Note
What does that mean
no-name
Galaxy Note
Galaxy Note
this might be image issue? Someone else was pointing out this black crush issue. I suggest you to check with uniform black pic from google search. search with pure solid black image and then use image to test screen.
no-name
Galaxy Note
Galaxy Note
can you check with solid black color image and put a screen shot if you see similar issue?
Galaxy Note
check this wallpaper. my screen is uniform no black crush.
aditya27
Galaxy Note
same issue in my s8
mk99
Galaxy Note
r u facing this issue since last update.
no-name
Galaxy Note
no,
since 8 months
