note 8 display problem
(Topic created on: 04-19-2020 10:35 PM)
no-name
Galaxy Note
Black Crush and Gradient Banding Issues
Is that any one facing the same ??
12 Comments
CS_member7
Galaxy Note
Dear Samsung member,
Be assured below given steps would help you out to solve the issue :-
1. Settings > Display > Adjust the brightness.
2. Check device in safe mode > Power off the device.>>Press and hold the Power key for one or two seconds to turn on the device > When the Samsung logo appears, press and hold the Volume down key. Exit safe mode by restarting the device again.
3. Update software:- Software update > Download and install > Download > Install now.
4. Reset the device. (Kindly create data backup of your device via SMART switch mobile application
or http://www.samsung.com/in/support/smartswitch pc suite).
If issue still persist please do send the log file via, Samsung member > Get help > Send feedback > Error reports > Select Symptom category. So that we can provide you the better assistance.(Note:-You are requested to send it within 15 minutes of problem occur).
Thanks for writing to Samsung.
ChiragArora
Galaxy Note
same problem in my S9 Plus.
SubramaniamJ
Galaxy Note
got this on my note 8 too...no idea what to do
