note 8 battery weak
(Topic created on: 05-11-2020 06:15 PM)
kersy
Galaxy Note
Hi my note 8 is just a year old.
After a 100%full battery at night, I wake up to find it at 82% . The bluetooth is off the sync is off ...
Any idea why this happens?  During the day too with minimal usage I need to charge it 2 to 3 times. Would be grateful if one of the members can give some useful tips/solutions. Thanks
10 Comments
Not applicable
Galaxy Note
LOL
Mirens
Galaxy Note
Make your note 8 Lineage OS 17.1 for good battery life, if you have note 8 exynos version.
kersy
Galaxy Note
how do you do that.?
Mirens
Galaxy Note
Mirens
Galaxy Note
For gaming its havoc os https://youtu.be/V5NA4Q1QG_Q
oyemukul
Galaxy Note
my s8 is 1.5 years old but drain in whole night is very minimal 3 to 4 %
but on day time i also need to charge 3-4 time.
Ashwin98
Galaxy Note
Hi kersy try these tips
Settings-> Device Manager->Battery->Optimized and also enable Adaptive power saving
Also regular advice to turn off auto rotate, sync,bluetooth, Wifi and location.
I think this may help you...
kersy
Galaxy Note
thanks Ashwin
Samsung_Support3
Galaxy Note
Dear Samsung Member,
Please perform the below mentioned steps to resolve the issue:
1. Perform Battery Optimization:- Battery optimization helps you to boost the battery performance of your device.
To check battery optimization:- Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
2. Device network fluctuation:- Kindly check whether mobile network fluctuates frequently or network signal is low in your area. In both cases battery will drain considerably fast. We recommend you to avoid usage in area with low network/fluctuation.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
