low call volume fix anyone?
(Topic created on: 06-18-2019 06:29 PM)
wasee
Galaxy Note
Anyone firgured out a way to fix the low call volume post pie update?
Im sick of talking on loudspeaker.
13 Comments
xdgone
Galaxy Note
there is a protective thing installed already which will not allow dust to move inside . i think you should know that .. that layer sometimes got blocked by dust that's why it needs to be cleaned by this way ..cause of that layer even water finds hard to move inside
as the model is Galaxy Note 8
wasee
Galaxy Note
how about a sticky tape to pull the dust out.
I have used phones that lasted 4 years in the past and never faced this issue... this one just 1.5 year 🤦‍♂️
makchaudhary
Galaxy Note
take a toothbrush with micro brussels. open the speajer grill holes with the help of it.
i did it few days ago....i have done it 3 4 times.
xdgone
Galaxy Note
toothbrush will damage the protective shield over speakers ( sapphire shield or IP and  MIL-STD standard shields over microphone and speakers ) which prevents dust and water flow inside the device
check the mobile servicing manuals
better use moist tissue paper or cotton cloth or cotton with a dust vacuum cleaner
( as directed im Smartphone service and maintance manuals )
