low call volume fix anyone?
(Topic created on: 06-18-2019 06:29 PM)
wasee
Galaxy Note
Anyone firgured out a way to fix the low call volume post pie update?
Im sick of talking on loudspeaker.
13 Comments
xdgone
Galaxy Note
in-call menu click the three dots and check for extra volume..
wasee
Galaxy Note
There is no such option..
xdgone
Galaxy Note
Your model??
wasee
Galaxy Note
Galaxy Note 8
Ahsanshhahh
Galaxy Note
Most of devices has option of Extra volume when you are on call.
wasee
Galaxy Note
It was there prior to pie update.. now it isn't
Goldychahal
Galaxy Note
one ui doesn't have that option.. they removed it..
xdgone
Galaxy Note
the solution for your issue is weired
take a cotton cloth than gently squashing in water try to clean speaker surface and than do a factory reset
or with the wet cloth you can use a vacuum cleaner or vacuum dust cleaner too
makchaudhary
Galaxy Note
no...dont do it...it will push dust further into the mesh
