charging problem
(Topic created on: 02-14-2019 12:56 AM)
AbhinavRai87
Galaxy Note
What should I do for this problem.... Dont know from where it get moisture even me and my phone was completely In dry mode ...How long should I wait for resolve this problem
6 Comments
Selvam
Galaxy Note
water has went through the USB port. dry it asap through hair dryer.
pankajur
Galaxy Note
https://youtu.be/QGCx7QkzdcQ
jig1
Galaxy Note
use hair dryer in usb port
if it's not work visit service center
pankajur
Galaxy Note
admin_
Galaxy Note
"Thanks for inquiring. We would like to inform you that this handset is enriched with the best available features. Kindly follow the below mentioned steps to overcome the issue:
1) We recommend you to charge your handset with original wall charger that came with your handset sales pack.
2) Check whether UPS (Ultra Power Saving) mode or PS(Power saving) mode is activated (if yes Deactivate it during charging).
3) Kindly clean the charging point of your charger and battery with a dry and soft cotton cloth to remove unwanted accumulated dust/waste material.
4) Kindly follow the standard charging procedure (Charge your device for 150 minutes on switch off mode).
samloverindia
Galaxy Note
how did it get solved.
