camera light sensor battery drain
(Topic created on: 07-27-2020 02:00 AM)
srp1985
Galaxy Note
Hi, Last couple of days , i have observed that camera light sensor is consuming battery to the tune of 5-8% . What is this camera light sensor ? I didnt find this earlier ? Why is it showing now .
Mobile - samsung galaxy note 10 lite.
8 Comments
S_Kumar73
Galaxy Note
This may be due to front camera used as face unlock. just turn off once and check. Even in face unlock settings there is one option called increase brightness to unlock in dark area. turn off. I'm also using note 10 plus. I tested apps from the setting. there is no such files.
srp1985
Galaxy Note
i am not using front camera to unlock phone. the adaptive brightness has been always on from day 1. why is the drain started showing since a few days back. Moreover , adaptive brightness is an imp feature of the phone. i dont want to manually control the screen brightness . There has to be some other solution to this
Galaxy Note
Turn off adaptive or auto brightness mode amd also turn off face unlock and check,but there is no permanent solution..
S_Kumar73
Galaxy Note
have you installed any 3rd party apps which might creat this issue. otherwise it's bug. either you have to flash software @ service center.
cs_member9
Galaxy Note
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
huwgt
Galaxy Note
this doesn't solve the rpoblem at all
yihuan
Galaxy Note
Hi, is this problem resolved for you? i am also using note 10 lite. This system app is draining around 8% every 24hr
Members_YUwTZjQ
Beginner Level 3
Galaxy Note
I'm facing the same issue. Adaptive brightness can be turned off but this is not the solution. Did you get any fix for it?
