Resolved! Solved
Camera light sensor Battery draining issue in Galaxy Note 10 Lite
(Topic created on: 01-09-2022 06:32 AM)
pramodn85
Galaxy Note
Recently I have noticed that my device's battery drains quickly without using much. So I did some investigation using battery information and it seems to be the camera light sensor which is the cultprit causing this drain. I am not sure if
this is only with my Galaxy Note 10 lite. If it is a global issue after the update then Samsung should do something to resolve it.
2 Solutions
WalkieTechie
Expert Level 4
Galaxy Note
Brother do you have auto brightness ON? Kindly, switch it OFF and then you won't face this issue.
WalkieTechie
Expert Level 4
Galaxy Note
Great bro. Actually new smartphones use the front camera sensor for light sensing. Hence the additional battery drain was there.
Now, as the issue is resolved, you can click on the 3 dots and accept this as solution.
8 Comments
Not applicable
Galaxy Note
Run your device in safe mode for an hour or two and lemme know whether in safe mode, this battery drain is noticed or not
pramodn85
Galaxy Note
Not yet tried, will do
Not applicable
Galaxy Note
Go to settings, Display, turn off adaptive brightness.
WalkieTechie
Expert Level 4
Galaxy Note
pramodn85
Galaxy Note
I noticed after Disabling Auto brightness battery draining is slower as compared earlier. Backup has been improved.
WalkieTechie
Expert Level 4
Galaxy Note
S_Kumar73
Galaxy Note
I think it's 3rd party app. I don't have this in my note 10 plus and note 10 lite
pramodn85
Galaxy Note
I will check for this too
