battery issue in galaxy note 10
(Topic created on: 02-13-2023 06:17 PM)
metalsupply
Galaxy Note
We bought a Samsung Phone for our company 10 months back and we are facing a display issue in it. I'm from Metal Supply Centre best Stainless Steel Sheet Supplier
cs-member11
Galaxy Note
Dear Samsung Customer,
If you attach a ''screen protector'' or optional accessories to the ''touchscreen'', the touchscreen may not function properly. Especially, some ''Samsung-Unapproved protector glasses'' or films only have tapes on the side edges.
When you attach such products to the device, protector film or glass may not be in perfect contact with the device and may get loose from the device.
This causes that some areas of the touchscreen may ''not recognize touch'' actions and no respond.
We recommend to use only ''Samsung-approved accessories'' and using ''unapproved accessories may cause the performance problems'' and malfunctions that are ''not covered by the warranty''.
Please follow the below steps, If the battery is non removable:
Press the power and volume down key simultaneously for few seconds.
Have you recently change ''device display'' from the service center?
In case ''non-genuine LCD/Touch panel'' is used on your device, similar problem may occur after Android OS Update.
Samsung recommends repairing your device using original Samsung parts at ''authorized Samsung Dealer/Service Center''.
Thank you for writing to us.
Samsung Customer Support.
