Samsung Note 20 Ultra Battery
(Topic created on: 09-16-2020 01:11 PM)
IshdeepSingh
Galaxy Note
Hi, I have been using the subjected device for 20 days now and it seems like I am not getting the juice of a 4500 MaH battery.
Its screen on time is hardly 4.30 hours.
Will this be rectified with future software updates.
I am using Exynos version and see alot of people facing the same issue for SUCH AN EXPENSIVE device...
#battery #Note20Ultra
13 Comments
Galaxy Note
Bro it will be hard to hear, but according to my experience there won't be any significant change in battery performance or performance overall. So I will suggest you to not to keep your hopes high, Because this Exynos 990 chipset is too power hungry and yet underperforming processor.
(I am guessing you are using 120hz mode).
If even on 60hz you are getting that low SOT (without gaming and stuff) you should visit a service center.
NoteFun
Galaxy Note
Sir, wait for the update and do not expect much from that too..Better charge it twice or when ever required and enjoy the flagship....
sagarb
Galaxy Note
min always 120hz lte on gets 6hrs+ in avg
IshdeepSingh
Galaxy Note
which Device are you using?
sagarb
Galaxy Note
N20 ultra
IshdeepSingh
Galaxy Note
Thank You guys, I am categorically monitoring my usage today... let's see... will update here...I am using;
120 Hz
Medium - High Brightness
Moderate usage
Some gaming like Clash of Clans..
and office emails plus social media..
minimal usage!
indras0007
Galaxy Note
My n20 ultra screen freezing issue, back button frequently turn on, many time my keyboard getting back and I'm not able to type, freezing contact, not able to make call, freezing problem with other app too.
I'm regular use note every model but but with 20 ultra I'm not happy, and it's happen after 19 day
IshdeepSingh
Galaxy Note
Hi... I believe, your device has genuine issues... you need to visit Samsung Store and get it rectified.... this doesn't seem to be a software issue
