Resolved! Solved
Problem in display Samsung note 10 plus
(Topic created on: 08-31-2019 12:27 PM)
Samsung_rwO4jhx
Galaxy Note
I have been seeing some problem in my display of Note10+. A small blinking light next to selfie camera during calls. Some times speaker also creating strange
sound during the calls
SarthakDhiman
Galaxy Note
don't worry bro it is proximity sensor . you should google for manual and as far as speakers are in concerned then go and visit Samsung care centre.
8 Comments
Not applicable
Galaxy Note
lol bro i have already post this problem and its a proximity sensor for calling , so don't panic . try with your finger to cover and uncover while calling.
harshgupta1
Galaxy Note
Please visit neary by Samsung store for help
Not applicable
Galaxy Note
its a proximity sensor. no need to go.
SarthakDhiman
Galaxy Note
ragnigupta
Galaxy Note
please visit the samsung service center near by your home
Deepaktolani
Galaxy Note
You don't have to go any where it's the proximity sensor only. This will happen when you are on call and not on speaker.
Niketvaghela
Galaxy Note
there is no problem. Just lack of knowledge/sense
prasad66
Galaxy Note
even the latest handset has started to give problems
