Note 9 battery Issue on One Ui 2
(Topic created on: 01-06-2020 02:45 PM)
Ajverma
Galaxy Note
Hello Members,
I think Samsung degraded our phone battery capacity to 20 to 25 percent on android 10.
My battery wear level was fine on pie and no issue showing in Interactive check in samsung member application. But now its showing Bad.
One of user also complaint same..
Please few of members check on their device which are on Android 10 and share the result.
12 Comments
Not applicable
Galaxy Note
samsung members interactive checks is not trust able
Galaxy Note
I have purchased care pack for my note 9 for 2nd year, the one with battery coverage. Do u think Samsung will change battery on grounds that there Interactive check showing battery health bad in Samsung members app? I mean if battery is not found to be leaking or swelled physically, will they change battery in care pack on basis of there app Interactive check. Helpline said to visit service centre. Any suggestion from ur end.
Not applicable
Galaxy Note
this app is inaccurate even I am also facing this issue no need to worry about this thing
Bş
Galaxy Note
yes android 10 has degraded battery life and back up.
Samsung needs to fix this otherwise I am thinking of degrading back to android 9.
Not applicable
Galaxy Note
is it possible? how to do it?
aayush
Galaxy Note
I have already rolled back to Android 9 after using the beta of OneUI 2.0
VasuKharb
Galaxy Note
shows "Good" in my Note9 after Android 10 One UI2. though the battery performance seems reduced
Not applicable
Galaxy Note
this is Samsung members faulty check ups
VasuKharb
Galaxy Note
Yes, Samsung really **bleep** at updates. I have always been a Note fan since the first Note arrived in 2011. The only reason I buy Samsung is because of Note series else I wouldn't think twice before getting myself Oneplus or iPhone.
