Note 9 SW Issue SIM does not work
(Topic created on: 06-24-2020 12:34 PM)
NitinJhanwar
Galaxy Note
Hello
After updating June SW update to Note 9...SIM card does not work.
SIM card is not getting detected.
Please suggest how to fix it
5 Comments
everbright
Galaxy Note
whether you tried for another sim
NitinJhanwar
Galaxy Note
thanks for your idea.
I had to get new SIM issued from airtel..and this problem is solved
Not applicable
Galaxy Note
bro you simply downloaded it?where that 2.1 need to be flashed which is actual and recommended procedure
MOHAN6642
Galaxy Note
DEAR FRIENDS,
I HAVE PURCHASED SAMSUNG M30S MOBILE.
THIS MOBILE SIGNAL RECEPTION IS VERY WEEK. CONFIRMLY I WILL BET SAMSUNG TECHNICAL PEOPLE ALSO WITH 100000/_ REGARDING SIGNAL RECEPTION IS WEAKER THAN OTHER MOBILES LIKE XIAOMI, REALME LIKE CHINESE MOBILES. DONT PURCHASE THIS MOBILES . THEY ARE PROVIDING THEIR ' EXYNOS ' WORST PERFORMING PROCESSORS. THIS IS REAL WHAT I AM TELLING . BELOW I HAVE GIVEN SIMPLE EXAMPLE FOR YOU.
FOR SAMSUNG S20 MOBILE , THEY ARE PROVIDING THEIR WORST 'EXYNOS' PROCESSORS IN INDIA , FOR THE SAME MOBILE IN AMERICA THEY ARE PROVIDING BEST SNAPDRAGON 865 PROCEESOR . EVEN THEIR KOREAN PEOPLE ALSO HATED THE SAMSUNG 'EXYNOS' PROCESSOR PERFORMANCE IN ' SAMSUNG S20 ' MOBILE.
AND THEIR SERVICE ALSO VERY WORST. TODAY I VISITED THEIR SERVICE CENTRE TO RECTIFY THE CHARGING PORT PROBLEM , HE TOLD THAT IT WILL TAKE ONE WEEK TO 10 DAYS TO RECTIFY THE PROBLEM . THIS IS A SMALL PROBLEM . I TOLD HIM TAKE THE COMPLAINT , AND GIVE MY MOBILE BACK , AFTER ONE WEEK I WILL COME AND I WILL GIVE THE MOBILE AND RECTIFY THE MOBILE WITH NEW PART . HE REFUSED FOR THE SAME . REGARDING THIS ALSO I CALLED THEIR CUSTOMER CARE , THEY ARE NOT ABLE TO TELL WHERE THE PART AVAILABLE TO THE NEAREST SERVICE CENTRE IN GUNTUR DISTRICT.
OTHER COMPANIES ARE DOING SMALL PROBLEMS WITH IN ONE DAY. BUT SAMSUNG IS TAKING 10 DAYS . THIS MUCH OF WORST THEY ARE DOING SERVICE.
THEY ARE RELEASING NUMBER OF MODELS WITH SAME PROCESSOR 'EXYNOS 9611' BUT NOT MAINTAINING PROPER SPARE PARTS AT THEIR SERVICE CENTERS . THEIR SERVICE CENTER PEOPLE ARE BEHAVING LIKE GAZITTED OFFICERS. FIRST OF ALL THIS IS THE MAIN PROBLEM WITH SAMSUNG.
Samsung_Support3
Galaxy Note
Dear Samsung Member,
Please perform the below mentioned steps to resolve the issue:
1. Check network operator settings
Settings > Connections > Mobile networks > Network operators > Select automatically > OK > Registered on network.
Note: We recommend to set device network operators as LTE/3G/2G (auto connect) mode.
2. Check SIM cards in other smartphone.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
