Note 8 September Update Battery Drain
(Topic created on: 09-15-2019 01:49 PM)
Nexian
Galaxy Note
Looks like this is bad update! After the September Update Battery backup has dropped drastically easily by 2-3 hours!! Dalvik cache clean did not work much, usually does.
Hope you fix it. Has made the phone laggy as well on the UI front.
Another issue is fast charging times have decreased. Seems to be charging like a normal charge.
12 Comments
Not applicable
Galaxy Note
yes that's I told him...may the procedure some how risky for unknown..thatswhy advice to go to service center
AnkitBhagat
Galaxy Note
same thing i m facing after this september update in my S8. phone is taking more time to charge and the 🔋 drain more quickly
kersy
Galaxy Note
battery drains fast... like 96%to 63 % in 4 hours with hardly any use... no background apps device maintenance shows optimized to 100%... donno why Samsung does not cater to 2 important things battery and speed...
