Note 4 battery issue.
(Topic created on: 07-08-2017 01:04 PM)
Dpd
Galaxy Note
My note 4 switching off automatically when battery goes down to 20 to 30 %. Anyone else is facing similar battery problem and what is the solution?
10 Comments
adiyash
Galaxy Note
yes
Dpd
Galaxy Note
you found any solution for this. or we have to change battery?
13Anmol
Galaxy Note
How old is your battery.
Dpd
Galaxy Note
1.5 years
13Anmol
Galaxy Note
Then i guess its the time to replace it because the life of a battery is 1-2 years and after that it starts draining quickly. But before buying a new one ask the service centre executives about your battery ,is it ok or not.
Dpd
Galaxy Note
thanks. but battery is not draining fast. once it's reached to 20% switch off and restart cycle starts multiple times.
13Anmol
Galaxy Note
You can try using your phone in safe mode.
This happens when the battery get old so this was the reason why I mentioned earlier to replace it. You can also try recalibrating your battery.
Amolak00
Galaxy Note
will samsung give us a assisstant update for jseries..
admin_
Galaxy Note
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
