Display Problem in Galaxy Note 9
(Topic created on: 08-03-2020 12:38 PM)
MilanGandhi
Galaxy Note
I am using Note 9 and suddenly since past few days anytime during the day the display becomes blurred with lines and yellowish in colour. When you increase the brightness to maximum level it becomes normal.
Can anyone help to resolve the issue
15 Comments
Vinu05
Galaxy Note
bro try to use the device on safe mode with blue light filter off and check the issue is still there or not if it's then there must be a hardware problem
Dilli
Galaxy Note
Time to have your display replaced no other solution is there
Vicky100ni
Galaxy Note
agar by chance Samsung esa koi update nikal deta h jis se screen issues thik ho jaye... tu pese de dega kya wapis... kya sbko bol rha h bar bar , screen khrab ho gya h??..new dlwa lo??... bhagwan h kya tu.. ek bnde ka fon khrab ho skta .. 2 ka ho skta h.. thousand of peoples facing this problem..without any dimag and pressure on screen,, 🤬🤬🤬🤬
Dilli
Galaxy Note
Then keep waiting for your update. I am not God but practical. 😡😡😡
PrakharMishra
Galaxy Note
Shut ur mouth of saying change ur device ....thousands of people facing the same problem of discoloration issue due to buggy update....If u cannot help them then dont twist the knife in the wound...
Dilli
Galaxy Note
shut your mouth you self conceited pompous a-s-s. keep waiting for expected update till next century. good luck
RubinTech
Galaxy Note
Samsung Note 9 Display Problems
Please Join only if you are facing the Display discoloration or Overheating or horizontal lines on display when the brightness is set to low. All these issues are started recently after software update, not by any accidental or physical damage to display.
https://t.me/samsungDisplayProblem
Aashish
Expert Level 4
Galaxy Note
Send Feedback through the Get Help tab.
Galaxy Note
bro there is simple fix. Enable always on display on your phone if you havent. Then lock ur phone and unlock. You can choose Tap to Show also in AOD. Let me know if this works.
