Charging problem
(Topic created on: 10-12-2023 11:10 PM)
sâtyamverma
Galaxy Note
2 Comments
Galaxy Note
bro , just charge your phone with low watts charger....
cs_member10
Galaxy Note
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Check the charging port
One of the most common causes of charging problems is if the charging port is blocked with dirt or dust.
Power off your device > The charging port should be cleaned > If the charging port is blocked, take it to a professional to be cleaned.
Try to use it with another Samsung Charger.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
