Battery issue
(Topic created on: 01-24-2022 12:22 AM)
Gaggnu
Galaxy Note
My google play services using too much battery done everything to fix it. This comes after one ui 4.0
17 Comments
ARJUNB
Expert Level 4
Galaxy Note
Yes I have been reading this issue well right now itself on my m51 which is android 11 one ui 3.1 is having this problem from a very long time look at this. Image you will understand. What on earth it is using in the background. Can anyone through some light here. 1642965725212_1642965725199_0.jpg
WalkieTechie
Expert Level 4
Galaxy Note
Check the steps I mentioned, it should help you brother.
WalkieTechie
Expert Level 4
Galaxy Note
1. Update Google Play services and Google play store
2. Go to Settings > Apps > Google play service > Clear data
3. Check if you have multiple Google accounts added to your phone and whether sync is ON for all of them. Turn sync OFF for accounts you don't need.
If you find this useful, you can click on the 3 dots and accept this as solution.
ARJUNB
Expert Level 4
Galaxy Note
Sync is only on for Google chrome and nothing else as for the accounts no sync is working.
WalkieTechie
Expert Level 4
Galaxy Note
Okay, then please go 1 page pack and share the screenshot, which shows how much battery has Google play services has actually consumed.
Gaggnu
Galaxy Note
I have done everything but didn't helped
Problem stays same
Gaggnu
Galaxy Note
I m using note 20 ultra wirh snapdragon
Not applicable
Galaxy Note
Please help me also . I am facing the same problem
WalkieTechie
Expert Level 4
Galaxy Note
Please share your screenshot 1st of battery usage.
