04-04-2023 08:52 AM in
Galaxy Note- Mark as New
04-08-2023 01:13 PM in
Galaxy NoteDear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Warm regard,
04-27-2023 09:36 PM in
05-02-2023 10:09 PM in
05-03-2023 06:42 PM in
Galaxy Note2again go to Google-devices-nearby share turn off this
3again Google click on upper three dots-usage and diagonstics Turn off this
4 go to setting-location turn off
Location-location service turn off two scanning
Go to setting and search vibration turn off at your uses
I hope it helps 😊
10-04-2023 02:34 PM in
Galaxy Note
