01-25-2021 08:45 PM in
Galaxy NoteSolved! Go to Solution.
02-02-2021 10:13 PM (Last edited 02-02-2021 10:14 PM ) in
Galaxy Notef you are in battery problem please do three things.. its a simple trick i followed..
1. back up and reset the phone
2. after that wipe cahche partition (simple like reset)
3. just load your note with new apps dont copy from any phone or cloud links.
atlast i will give you the best trick to make your note to work in 120hz with power saving mode but before that finish and say ..
thank you
01-25-2021 08:51 PM in
Galaxy Noteeven you close apps but they uses ur battery and running in background unnecessary, see image(1) and read the statement.
2nd due to huge notification options.
for e.g ; Google has huge notification which we don't need at all see image(2) just scroll up and down and check how many notification it does have.
So do these settings to stop, which consume battery unnecessarily.
1. Settings>>Connection>more connections settings> disable nearby device settings
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
Galaxy Note3. Device care>battery >power mode>select "optimised" and "adaptive power saving".
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
01-26-2021 01:33 AM in
Galaxy Note- Mark as New
01-27-2021 10:04 PM in
Galaxy NoteDear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
thank you
02-03-2021 08:04 PM in
02-03-2021 08:13 PM in
Galaxy Note
