fast charging vs normal charging? battery efficiency
(Topic created on: 11-26-2020 10:56 PM)
KirKirKiran
Galaxy M
Can i improve screen on time if i charge in normal charging mode.? Any difference with fast charging?
Also I wanted to know when to start charging and upto what percentage to charge for battery safety and efficiency
10 Comments
RohitRk
Galaxy M
yes in normal charging mode battery backup is better from fast charging mode
Shank_Sar
Galaxy M
Try to normal charge, fast charge only when needed. I prefer to keep battery within 40 to 90%.
RohitRk
Galaxy M
to get better battery safety and efficiency charge your phone to about 80-85%
nbhowmik3
Galaxy M
me 15-80
Not applicable
Galaxy M
bro both are better.....but it's better to use normal charging if possible.... fast charging produce extra heat which can minimize battery health later
RickyM51
Galaxy M
u can see the effect of fast charging in long term.... fast charging degrades the battery faster..
Vikramus
Galaxy M
Use micro USB charger
Anikroyale
Galaxy M
Tell me some ways in which a person can use a micro USB charger in an USB Type C device.
Galaxy M
If you're planning to use your phone for more than a year or two. Then only you have to charge your device in normal mode. Otherwise you can charge it fast. Charge your device between 20 to 90 % it's good for battery health. You can also top up your battery from 40 or 50 % to 90% It will not harm your battery.
