04-16-2025 01:06 PM (Last edited 04-16-2025 10:11 PM ) in
Galaxy MSolved! Go to Solution.
04-16-2025 01:53 PM in
Galaxy M- Mark as New
04-16-2025 04:29 PM in
04-17-2025 11:39 PM in
04-16-2025 09:40 PM (Last edited 04-16-2025 09:41 PM ) in
Galaxy MAlso my device is heating crazy in normal usage
04-17-2025 09:17 AM in
Galaxy MDear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
04-17-2025 09:31 AM in
04-17-2025 11:40 PM in
04-19-2025 10:05 AM in
Galaxy M
