M06 battery and heating issues
(Topic created on: 10-11-2025 07:00 PM)
Radhechoudhary
Galaxy M
M06 have 5k mah battery but it acts like only having 4k and running time also low and phone getting frequent heated... evan I'm not heavy-user it drain more faster thn my tab.... kindly fix this rather thn giving next extra features 🙏
8 Comments
Galaxy M
I've 6/128 वेरिएंट
PSYCHO6740
Galaxy M
try clearing cache partition
if not helps then reset or wait for update (update might likely fix it)
Galaxy M
It's brand new device (with latest security patch
PSYCHO6740
Galaxy M
ik, i have a06 5g model running pretty good atm but with some bugs waiting for one ui 8 and hoping that it will get fixed
goodthings
Galaxy M
goodthings
Galaxy M
You're welcome to here.
cs_member10
Galaxy M
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
8. Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
Galaxy M
Wah.. I've brand new phone and in same conditions my old phone with lower mah is giving more running time... this is ui problem not my!
