4 weeks ago in
Galaxy M- Mark as New
4 weeks ago in
4 weeks ago in
Galaxy MDear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
8. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps).
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.)
3 weeks ago in
2 weeks ago in
Wednesday in
Galaxy M2. Reduce screen brightness.
3. Adjust display refresh rate to standard mode.
4. Turn off connectivity.
Disable Wi-Fi, GPS, and Bluetooth when not in use.
5. Turn off AOD.
If you like this solution.
Please
Accept as a solution .
Wednesday in
Galaxy Mor
Put in deep sleeping which apps not in regular usage.
2. Uninstall extra apps
3. Battery optimization.
4. Closed all background applications
Please
Wednesday in
5. Turn off AOD.
Please
Wednesday in
Galaxy Mor
Please
