Battery Optimisation Problem
(Topic created on: 10-04-2024 03:28 PM)
soumo_dg
Galaxy M
This is Galaxy M55s 5G having 5000 mAh battery but this is my battery draining stats.
Is this good? My 3 years old realme (4500 mAh) gives better battery backup than this brand new phone.
Battery stat screenshot
17 Comments
Harishhvr
Galaxy M
How many mah battery and which phone
soumo_dg
Galaxy M
Galaxy M55 and 5000 mAh
Harishhvr
Galaxy M
Yeah bro worst battery
Harishhvr
Galaxy M
M55 is a failure model so the samsung re launced by changing the name M55s
soumo_dg
Galaxy M
Yes, I bought the M55s.
Exynos9611
Galaxy M
waste of money phone m55s
soumo_dg
Galaxy M
Not actually. I love One UI.
cs_member10
Galaxy M
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
