Battery Optimisation Problem
(Topic created on: 10-04-2024 03:28 PM)
soumo_dg
Galaxy M
This is Galaxy M55s 5G having 5000 mAh battery but this is my battery draining stats.
Is this good? My 3 years old realme (4500 mAh) gives better battery backup than this brand new phone.
Battery stat screenshot
17 Comments
Abpal
Galaxy M
What is your realme's screen on time ?
soumo_dg
Galaxy M
Comparatively, more than what Samsung is offering.
Abpal
Galaxy M
Can you share your Samsung's screen on time with close to 100% battery usage ?
soumo_dg
Galaxy M
Abpal
Galaxy M
Umm, by these stats, there is actually no battery issue in your device. Also, I am assuming you are using 5g.
soumo_dg
Galaxy M
No, 100% on Wifi. These Battery stats are a little fuzzy. Like it burnt 98% total and showing 89%.
Also most apps are either sleeping or deep sleeping.
Abpal
Galaxy M
Battery backup is good. This is the maximum you can get. Else, you would need to bring down settings like turning off high refresh rate, etc.. which obviously you wouldn't want in such a costly phone😂
soumo_dg
Galaxy M
Bro, It's on 60Hz. That's why I'm saying it's draining the battery considering it's a new phone.
Abpal
Galaxy M
Then, it's concerning because I have a33 5g (2 years old) having exynos 1280 and have exact same battery usage as you mentioned that too with gaming but, with 90 hz.
I guess it's due to the processor, it is draining more in your case. So again you can't do anything.
