10-09-2024 09:20 AM in
Galaxy M- « Previous
- 1
- 2
- Next »
10-09-2024 04:33 PM in
Galaxy MDear Samsung Member,
As per your concern, we want to inform you that the usage of the battery is different for every application, some apps consume more battery depending on the screen time, network fluctuation, refresh rate, etc. Kindly perform the following steps to resolve your issue by using the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Compser> Select error report> select the appriopriate issue category> Type your query and send.)
10-18-2024 04:12 PM in
Galaxy M- Mark as New
11-27-2024 10:31 AM in
12-03-2024 07:19 PM in
02-10-2025 02:56 PM in
02-28-2025 12:51 AM in
03-03-2025 09:55 PM in
04-14-2025 10:35 PM in
Galaxy MSame issue I also faced and I purchased this phone on 12th April 2025 and today is 14th April 2025 only 2 days and battery backup is not expected as there are 6000mAh battery
4 weeks ago in
2 weeks ago in
Galaxy M
- « Previous
- 1
- 2
- Next »
