Battery Drain Issue on Samsung M35
(Topic created on: 10-09-2024 09:20 AM)
BariRohit
Beginner Level 4
Galaxy M
Hey Samsung Members,
I’ve been facing a noticeable battery drain issue on my Samsung M35 recently. Even with very simple usage like browsing, calling, and light messaging, the battery backup is only lasting about 5 to 6 hours, which is far less than expected. I’ve already tried common fixes like reducing brightness, turning off background apps, and disabling unnecessary features, but nothing seems to improve the situation.
Has anyone else encountered this issue with their M35? Could this be related to a recent software update, or might it be a hardware problem? I’d really appreciate any suggestions or solutions from the community. Thanks in advance for your help!
19 Comments
Mayur000
Galaxy M
Browsing eats the battery based on websites..
+ Turn on the battery saver mode for a 48 hours.
And check it improves time?
KaranJain29
Galaxy M
Battery saver damages your battery..
samnull
Galaxy M
There is various step in solution as stated which you can try to fix
samnull
Galaxy M
1. go to settings > apps > one ui home > battery > select the optimized option
samnull
Galaxy M
2. Charging with another charger (not samsung official charger) can damage the battery's life quickly, so only use samsung official charger
samnull
Galaxy M
3. If you have already followed the above steps you can try to turn-off fast charging option
samnull
Galaxy M
This will solve your problems within two to three days
goodthings
Galaxy M
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy M
Your's most welcome to here.
